112 John Deere
Adam Coleman
05-31-2006 12:06:44
I am needing the entire pully assembly for a 112 John Deere with the 12 horse Kohler with a 1.125 inch shaft. I would appreciate any and all help please.
apekim
05-31-2006 13:38:55
 Re: 112 John Deere in reply to Adam Coleman, 05-31-2006 12:06:44
I assume you are refering to the cone type clutch pulley assembly. The 112 should have a 1" crank shaft diameter.
The 1-1/8" diameter shaft was used on Ford, Jacobsen, and a few others (and they used the electric pto). The shaft lengths are slightly different also (maybe 1/4" or so). If your engine was replaced with one of these, then you might have to get a standard 110 or 112 pully assembly and have it machined to fit the crankshaft diameter.
I can get you the exact dimensions of a standard 110 or 112 Kohler powered crankshaft pto. You can then compare it to what you have, and go from there.
Mike
Adam Coleman
05-31-2006 14:20:35
 Re: 112 John Deere in reply to apekim, 05-31-2006 13:38:55
Thank you for the help.
