Case/Ingersoll 226
Mark
07-21-1999 18:45:07
I have a 226 with Onan 16 HP engine that is about 12 years old. The past 2 years during hot weather, I have been having problems with losing power, tractor stalling, and then not wanting to restart until it cools down. Dealer suggested that it was vapor locking and to install insulation around fuel line. Done that, didn't help. Someone else suggested that it sounded like a warped exhaust valve. Anybody else have any ideas before I invest in an overhaul?
Nick Skalini
06-19-2005 05:44:45
 Re: Case/Ingersoll 226 in reply to Mark , 07-21-1999 18:45:07
I would replace the gas cap. Sounds to me like vapor lock. What happens is your fuel pump can't keep up with the suction that is being created because your cap is plugged. This causes a lean gas mixture which causes your engine to run hot. With your engine temp increasing your carb and fuel lines are also increasing to a boiling point and your engine snubs. As it cools the pressure in your tank decreases and your can run again. Replace the cap, wrap the gas line with foil.
Scott Nelson
06-11-2002 19:34:51
 Kohler dies when hot...(no fuel) in reply to Mark , 07-21-1999 18:45:07
Dennis
08-29-2000 21:49:42
I have a 446 and had similiar problems...my tractor got SO hot my muffler was glowing red..i don't remember the name of the part but it cost about $1.46. I sits directly under the points..it was about an inch in length and about as thick as pencil lead
David Brown
07-21-1999 19:35:47
Mark,Try moving the coil to a cooler location on the tractor. Failing that try a new coil in a cooler location.
Ray's Mower Shop
07-21-1999 20:32:49
 Re: Re: Case/Ingersoll 226 in reply to David Brown, 07-21-1999 19:35:47
The Onan engines when they get some hours on them require the valves to be adjusted. This can be done with a valve job. What happens is when the engine gets hot the valves expand and don't have the right clearance not letting them seal properly. So the engine probably doesn't need an overhaul and the valve job can probably be done in the tractor.
troy barber
03-25-2000 12:30:18
 Re: Re: Re: Case/Ingersoll 226 in reply to Ray's Mower Shop, 07-21-1999 20:32:49
I have taken my clutch apart and now i cann't put it back together so it will run correctly.
when i engage the clutch, the engine with die out and eventually quit. do you have any schematics or information you can send me.
james snyder
06-10-2000 17:53:19
 Re: Re: Re: Re: Case/Ingersoll 226 in reply to troy barber, 03-25-2000 12:30:18
I have a 226 case i need to fix the muffler do you have any info on fixing it.
