BS 14.5HP OHV - I/C
DennyF
06-01-2006 15:05:27
This formally reliable critter suddenly began running rough and blowing a bit of black smoke yesterday while mowing. It starts right up, still runs rough, but is now also blowing some oil smoke and the occasional fire ball in the muffler.
Carb problem, or something "let loose" in the timing or valve train?
Only previous problem in the past 7 years, was when the fuel shut off circut wire developed a short and would cut out sporadically. Once I sorted out the cause and relocated/repaired the wire, no more problems.
JT
06-01-2006 15:43:54
 Re: BS 14.5HP OHV - I/C in reply to DennyF, 06-01-2006 15:05:27
Pull off your air filter and see if you have oil inside the air filter element. If you do, you have a blown head gasket, this is a very common problem with the single cylinder OHV engines.
DennyF
06-01-2006 18:26:03
 Re: BS 14.5HP OHV - I/C in reply to JT, 06-01-2006 15:43:54
No oil in filter box or filters. Pulled the shroud, no external oil leaks of any great concern, but the usual crud buildup around the breather tube.
Do have a seep around the dipstick tube "O ring" seal, but I've never run the thing low on oil.
JT
06-03-2006 06:47:59
 Re: BS 14.5HP OHV - I/C in reply to DennyF, 06-01-2006 18:26:03
The only thing that will make it suddenly start smoking black smoke is soemthing restricting the air intake. ie, plugged filter, choke shaft broke, choke on all the time. If this is not the problem, you need to do a compression test AND a cylinder leak down test to locate the problem.
