'77 sears not charging
cj3b_jeep
06-06-2006 06:25:08
My '77 sears 14/6 stopped charging the other day. I went to take the shroud off to check the magneto, but apparenly you have to remove the engine to accomplish this. Is there anything else I can check and eliminate as a problem before I take the motor off? It has the 14 horse Techumseh overhead valve engine
cj3b_jeep
06-08-2006 05:16:47
 Re: '77 sears not charging in reply to cj3b_jeep, 06-06-2006 06:25:08
I know what a diode looks like on a car, but what about this one?
David L. Wylie
06-06-2006 09:39:08
Your charging system lies under the flywheel. The first thing I would check is the Diode. It should be located outside on the frame of the engine. If all else fails you will need to pull the engine and check the Stator which is under the flywheel. Good Luck.
