16.5 OHV Briggs $ Stratton
Eddie Jones
06-08-2006 16:22:35
Need to know about compression release on this engine. How to adjust if can be. Any information would be a big help. Thank in advanced, Eddie
Kent of SW MO
06-09-2006 05:32:16
 Re: 16.5 OHV Briggs $ Stratton in reply to Eddie Jones, 06-08-2006 16:22:35
I think the specs are: .002" to .004" intake and .004" to .006" exhaust set with engine cold ang the piston slightly AFTER TDC on the compression stroke.
Kent
Eddie Jones
06-11-2006 06:06:52
 Re: 16.5 OHV Briggs $ Stratton in reply to Kent of SW MO, 06-09-2006 05:32:16
I set the intake at .003 and the exhaut at .005. That did the trick. It start like a new one. Thank-you for all your help, Eddie
Eddie Jones
06-08-2006 18:23:08
what would be the valve clearance spec. be on model# 313707 Thanks Eddie
Bob
06-08-2006 18:43:22
 Re: 16.5 OHV Briggs $ Stratton in reply to Eddie Jones, 06-08-2006 18:23:08
I don't know, offhand, not being at the shop.
The OHV's have very little clearance, and if too wide, the compression release won't work.
I believe you can find the valve specs on:
briggsandstratton.com
Bob
06-08-2006 18:04:33
Set your valve clearances to the exact spec for your model #, and the compression release should do it's thing!
