Pull start wont start
550Doug
06-14-2006 04:32:29
Got my 5hp B&S rototiller (pull start) started today and it ran about 10 minutes. I shut it down and came back an hour later and it just wont start. I pulled and pulled and I finally broke the rope. After struggling with the spring, I finally got the rope fixed but it still will not start. How do I check that I'm getting spark while I'm pulling? While I had the pulling mechanism off I checked for loose wires or anything looking burnt, but found nothing abnormal. Any ideas?
Thanks
landlord7012
06-14-2006 15:51:52
 Re: Pull start wont start in reply to 550Doug, 06-14-2006 04:32:29
Does it kick back when pulling it over? If so you have a sheared flywheel key (so you would see spark but it"s not timed right). That may be why the rope broke as well. Easy to check spark - remove plug and lay it on the cylinder head. Make sure it"s grounded and make sure your in a poorly lighted area.
ll
John Scott
06-14-2006 06:06:14
Hey Doug: I picked up a handy little tool for checking the spark. Its called an In-Line Spark Tester. Hooks to plug on one end and the wire on the other end. Found it at Harbour Freight Tools.
I have the same problem as you right now. I have an old two wheel walk behind Waterloo with a sickle bar on the front. I used it to cut the weeds and since I finished it will not start. I have a lot of fire but can't figure out why it won't start.
The engine is a 4.0 HP Clinton made between 1949 and 1954 but usually runs reeeeeal good.
Any ideas as to why it won't start.
teej
06-14-2006 08:46:37
 Re: Pull start wont start in reply to John Scott, 06-14-2006 06:06:14
Many times an engine that runs fine, then doesn't start after its been used and turned off, its because of a stuck valve. As long as you still have spark, and its getting fuel. Common on some older engines.
