BS vanguard not charging
genep
06-19-2006 13:19:23
I have 24v ac on the terminals from inside the engine shroud and less than one volt dc on the red (center )wire out of the rectifier. Is it safe to say I have a bad rectifier? Is there anything else I need to check? Thanking you in advance,
Gene
chevy65
06-20-2006 04:54:52
 Re: BS vanguard not charging in reply to genep, 06-19-2006 13:19:23
24v ac seems a bit low but i dont know the specs on ur engines charging system
there is output so i would suspect the reg rectifer because it should have 12v
genep
06-20-2006 05:19:13
 Re: BS vanguard not charging in reply to chevy65, 06-20-2006 04:54:52
yea, I checked it again with the engine at full speed and got 29v on my $6.00 digital meter. Who knows, it could be 25v or 35v :>) I just wanted another opinion before I drop $45.00 on a new rectifier.
