PULLING STEERING WHEEL ARIENS
AMERTRAC
07-05-2006 13:20:31
i have tried every puller i own with heat. i removed all the plastic off the steering wheel.
i tried heat .i can't cut if off becausr the shaft cover is plastic. other than tryig to remove the whole shaft i am stumped and bruised and bleeding and pizzed HELP it is an S series ariens thanks bob w.
Chad Matthews
07-10-2006 10:00:33
 Re: PULLING STEERING WHEEL ARIENS in reply to AMERTRAC, 07-05-2006 13:20:31
Be careful to not damage the threads.. I have two of these and one of them has the threaded steering shaft and had the wheel stuck on it. I mushroomed the threads somewhat even when being careful. Had to get a thread chaser and fix them up. A buddy of mine told me next time to take a felt washer for top post batterys and put it on the shaft and soak it with penetrant. Then install your puller and put a decent pull on it without trying to pull it off right then. Keep coming back everyday and resoaking the washer and tightening the puller. Are you rebuilding the steering sector?
oldrustycars
07-06-2006 07:30:02
Link
this is for a cub cadet, they also have steering wheels that are a PITA to remove. maybe it'll help.
elwood largey
07-06-2006 05:07:27
hi bob, is the steering wheel on the ariens i sold you with the loader? hope that tractor still treets you good. them steering wheels pretty much weld them selves on with rust. i have taken a sawz all and cut up and down ward in toward the steering shaft, dont cut into the steering shaft. if you get almost threw start to chisel it and it should come loose. then you need another steering wheel. ebay has them time to time.
amertrac
07-06-2006 05:56:07
 Re: PULLING STEERING WHEEL ARIENS in reply to elwood largey, 07-06-2006 05:07:27
yes thats the one . been a real good machine. very little maintenance. i added weight to the rear other then that nothing. you could not buy that back for the same price right now even without a steering wheel. lol
ps
07-06-2006 05:58:33
 Re: PULLING STEERING WHEEL ARIENS in reply to amertrac, 07-06-2006 05:56:07
and brakes and a garage door ha ha
