Tecumseh HM80 block
460paul
07-06-2006 20:04:54
I have a block from a Massey Ferguson 8 that needs bored. It was originally 3.0625" dia. Tecumseh also had HM80's with a 3.125" bore. I can't locate a .020 piston/ring set. They are not available anymore. Are these blocks the same and is there enough wall to just have mine bored to the 3.125" bore? Thanks, Paul
JT
07-07-2006 07:30:23
 Re: Tecumseh HM80 block in reply to 460paul, 07-06-2006 20:04:54
Is your engine a HH80 or HM80. There is a differance in the piston on a cast iron engine such as the HH80 and an aluminum engine with a cast sleeve such as the HM80. Could have been a differance in the pin hole on the piston, the lenght of the piston, lenght of the rod. If you will get me the model off your engine, I will look and see what I have, I do have several old Tecumseh pistons, so I will be glad to look and see what I have.
Greg_Ky
07-06-2006 21:43:45
Try Hastiings they should have a set of rings.
Hastings Manufacturing (269) 945-2491
www.hastingsmfg.com
