Kohler KT17
IA Roy
07-13-2006 19:42:06
My mower with this engine has only been running on one cylinder for a short while. I figured out which cylinder was missing by checking the plugs. I swapped the plugs and now it won't start. I checked to see if the plugs would fire outside the cylinder. There is a very weak spark from both plug wires. The missing started during a hard pull when a belt came off the pulley and started binding up. Any ideas where I should go next.
Kent of SW MO
07-15-2006 05:41:08
 Re: Kohler KT17 in reply to IA Roy, 07-13-2006 19:42:06
Try a new set of sparkplugs first.
Kent
Don L C
07-14-2006 17:12:09
Go up a couple post .... cli on the responce to get service manual for this engine.....if you only want to copy one page....example 22..."copy page 22 to 22" = 1 copy of page 22....Don
R Bedell
07-14-2006 03:26:43
Check your compression on both cylinders and see what you have.
