Adding Starters To non-starter engines ---
Don L C
07-14-2006 17:37:50
Since I lost my left leg and live in a wheel chair, I cant pull start small gas engines with enough snap / speed to start them.....boy was that a suprise.....
Do you think I could add a belt drive starter like on the old 12 hp cub cadet ?
Add a pipe welded to the flywheel nut with a pully on the other end..... belt driven by cub cadet starter....
Do you know of a better starter for this job?
Think about it and get back to me....
I have:
5.5 hp Honda pressure washer---
5 hp Briggs rototiller---
Iguess the weed wacker is out of the question....
Thanks Don
john d
07-14-2006 18:54:48
 Re: Adding Starters To non-starter engines --- in reply to Don L C, 07-14-2006 17:37:50
You can remove the recoil starter and add a "rope cup" on the end of the crankshaft, cutting a hole in the shroud for it. Then you can use a v-belt to an electric motor to start it. A half hp. motor might start it. The disadvantage to that setup is that you have to be within reach of the electric motor. Another version of that setup would be a 12 volt starter motor, battery and switch mounted on something that would let you use a v-belt to that rope cup.
I used to have a rototiller that I really liked except it was the meanest thing I ever had to start with a recoil starter. About half the time it would kick back and nearly break my hand. I put an extra pulley on the pto end of the crankshaft and used a long v belt to the electric clutch on my Wheelhorse. It would spin it until it started, even when it didn't want to! I also rigged a short piece of rectangular tubing to go over the top end of the tiller drag stake. With a wagon-tongue-style hitch on the other end of the tubing, I could tip the tiller, tow it backwards behind the Wheelhorse to the garden, then start it.
The old Cub Cadet starter system would probably work if you have a big enough pulley mounted on the crankshaft. Some old Wheel Horse and Deere models used the same setup.
You might consider selling your gas string trimmer and getting a battery-powered electric. Some of them are pretty good. My wife came home with a Ryobi electric about three years ago, and I groaned when I saw it. But I've got to say that for light duty trimming around the house it does a good job - and she uses it!
Don L C
07-14-2006 17:44:59
I tried using socket and 1/2" drive drill motor...a lot of "jerking" was afraid of snaping the nut off the crank shaft....I think the drill turns too slow....but they did eventualy start.....too hard on my 70 yr. old arms and shoulders....Don
Rustyj14
07-14-2006 18:48:27
 Re: Adding Starters To non-starter engines --- in reply to Don L C, 07-14-2006 17:44:59
Somebody gave me the attachment to install on a small lawn mower engine, where you can use your drill motor to start it. It consists of a cup to put on the flywheel, and a cone, with a rubber piece to fit the cone, and ability to be "chucked" into your drill motor, to start the engine. It obviously doesn't tend to break off the top nut on the crank-shaft, since only friction gets things turning. I fell down about 7 years ago, and stoved both shoulders, to the point that i couldn't drive my truck that didn't have power steering. But, going out most every night, to find throw-away mowers, helped me get over that problem pretty quickly! I'm approaching 82, and still can pull the mower ropes! Rustyj
