425 temp gauge not working
MBM1876
07-19-2006 07:30:23
I just bought a 2003 425 AWS with a 54 inch deck with 152 hours. My temp gauge is not working. Any thoughts?
chevy65
07-19-2006 08:51:01
 Re: 425 temp gauge not working in reply to MBM1876, 07-19-2006 07:30:23
Id check the thermostat if its stuck open the engine wont heat up much
the guage being bad is unlikly
you can also check the temp sending switch
id bet it a stuck open thermostat ive seen it to many times good luck
MBM1876
07-19-2006 09:51:44
 Re: 425 temp gauge not working in reply to chevy65, 07-19-2006 08:51:01
I have replaced the temperature sensor. Should I replace the termostat?
Bob
07-19-2006 13:37:29
 Re: 425 temp gauge not working in reply to MBM1876, 07-19-2006 09:51:44
Use the posslq's candy/oven thermometer or an infra-red thermometer, and verify how warm it is really running, before condemning the thermostat.
MBM1876
07-19-2006 14:34:35
 Re: john deere 425 temp gauge not working in reply to Bob, 07-19-2006 13:37:29
okay thanks. I talked with a JD mechanic and he didn't think it would be the thermostat. He said to check all wiring to the temp sensor and make sure everything is plugged in properly. What else can go wrong besides the temp sensor and the thermostat? i need help!
