12 hp briggs modifications
slwride
08-20-2006 14:16:19
are there any modifications i can perform to make more power while still using all stock componets? I'm building another garden tractor puller, and have decided not to burn to much money up into this one.
thanks, slowride>
RN
08-21-2006 18:10:20
 Re: 12 hp briggs modifications in reply to slwride, 08-20-2006 14:16:19
Basics- port and polish intake and exhaust. Some flatheads like Kohlers have slightly angeled valves so head is partially shrouded- relieve valve seat/block area- Cub Cadet furom had a short artice on that with a k241. Exhaust into straight pipe or expansion chamber. .010-020 planed off head to raise compression abou 1/2 point. Camshaft and timing require parts swap- lwave them stock unless want to spend $. Tweak governor up about 2-300 rpm only. Intake air cone between air cleaner and carb, match carb/gasket/port sixe. RN
tuke2
08-20-2006 17:45:20
Advancing the timing will give you a hp boost of about 1 1/2 to 2 hp.
slowride
08-20-2006 19:28:35
 Re: 12 hp briggs modifications in reply to tuke2, 08-20-2006 17:45:20
how do I advance the timing? it has a coil, so i Don't know how how that can be done
tuke2
08-21-2006 18:03:09
 Re: 12 hp briggs modifications in reply to slowride, 08-20-2006 19:28:35
Are you sure this is a Briggs engine? Sounds like a Kohler.
cadet trooper
08-20-2006 16:22:02
Hey slowride I can't help you on your pulling question but I've got a basket full of parts for a model 283707 type 0152 01 code 9305034D I need to get rid of them but I hate to throw them away. Rod bearing locked up broke a rod punched a hole in the block and the rest is history have a lot of usable parts minus starter and mag coil. Willing to work something out, crank was standard OD so can be turned and make a good spare. E-mail me at bottom selection we can work something out. CT
slowride
08-20-2006 17:24:32
 Re: 12 hp briggs modifications in reply to cadet trooper, 08-20-2006 16:22:02
sorry cadet. but I got enough "spare" parts lyin' around here already. AS much as I'd love to get more, space won't allow.
thanks for the offer
slowride>
cadet trooper
08-20-2006 17:41:00
 Re: 12 hp briggs modifications in reply to slowride, 08-20-2006 17:24:32
I know the problem, I feel the pain good luck. CT
