Wheel Horse Raider 12 trans problems
ACPhil
08-27-2006 13:21:18
My WH Raider 12 will not stop or let you change gears when the clutch/brake pedal is pushed down. I have installed a new brake band but still the same. My question on how power flows thru the trans: When Brake/Clutch pedal is depressed and brake band stops brake drum on left side of trans, should it also stop the drive pulley on the right side of the trans so the belt will slip. Trans does make some noise when brake is trying to hold tractor from moving. Thanks, Phil
Cub Cadet owner
08-27-2006 18:39:36
 Re: Wheel Horse Raider 12 trans problems in reply to ACPhil, 08-27-2006 13:21:18
Call here: Steve Myers S-tech (419) 645-4288, and ask for Steve.
He was a WH dealer for years and years!! He will be able to answer any and all questions you might have, and he is also a great source for parts for WH tractors.
