14hp kohler balance gears
Randy Reber
09-03-2006 19:43:07
Can I remove the balance gears without removing the crank? The gears have a lot of play in them so I think that is causing the knock. I checked the bore & it measures 3.502/3.503 & the cylinder has no score marks in it. Can I get away with just putting new rings in it? Model K321S Spec 60122d
randy reber
09-04-2006 07:28:04
 Re: 14hp kohler balance gears in reply to Randy Reber, 09-03-2006 19:43:07
Kent
Can it be repaired with out removing the crank?
Kent of SW MO
09-04-2006 07:04:50
Some people remove them, but if they are loose you need a new set of needle bearings. Kohler has a kit to do the repairs. I did one on a K-301 in Cub Cadet this spring.
Kent
