charging system
allen
09-04-2006 20:04:19
I have a 18hp honda engine in a cub cadet utility vehicle.The charging system is not working,does anybody have any experence working on these engines?
walt1
09-05-2006 04:44:57
 Re: charging system in reply to allen, 09-04-2006 20:04:19
Allen,
I just found this website,I have something that you might try,I had a problem with a riding mower one time that would start the first time, but when I would shut it off it would not start again, acted like it had a dead battery, but it was'nt.
After checking it over I discovered that it had a high resistance to ground at the connection of the battery to the chasis of mower. I removed the negative cable and filed and brightened connection area. This solved the problem.
Hope this helps
Walt1
