Cub 1000 dozer blade/will it work on Cub 1811
Sam
08-03-1999 22:02:41
Cub 1000 (manual lift) dozer blade needing to mount on Cub 1811. Anybody know if blade will attach or do I need modifications? Appears the lifting rod may not make it past the right engine cover without making contact. Should I expect other problems with the attachment of the main carrage system ? Any comments apppreciated.
m huffman
08-08-1999 04:09:06
 Re: Cub 1000 dozer blade/will it work on Cub 1811 in reply to Sam, 08-03-1999 22:02:41
it should work you may have to make or get a part to put on the 1811 to lift blade if you dont have a place all ready set up i had to make a lift point on my 1806 which was a piece of flat stock with a hole for the lifting rod and a ubolt that hooked to the manual lift handel
