Drive belt for 42 deck
Ed Hopkins
08-04-1999 16:21:41
I have a Cub Cadet 73 with a 42" mower deck that needs a drive belt. The local NAPA store can't cross reference the original part #s. I got a special purpose belt that was 77" long but have been unable to get it on. To short? Does anyone know the correct length for the drive belt??
At this point I'm shootin' in the dark and any help will be appreciated.
EdH
Ed
08-06-1999 09:49:00
 Re: Drive belt for 42 deck in reply to Ed Hopkins, 08-04-1999 16:21:41
Cub Cadets use a special angle V-belt. A std V-Belt will ride higher in the pulley and seem short. It will also be prone to turning and not last as long.
Your special belt may have the same v profile but cant be sure.
I would suggest you go to your local CC dealor for the correct belt. You can use this belt to match up an aftermarket brand.
The CC branded belts aren't that expensive so I've always used them.
good luck
Scott M. Harris
08-04-1999 18:46:13
Good Evening Ed,
I have a Cub Mod. 102 with the same deck. I went to our local Fleet and Farm store. THey had a parts book there for all kinds of garden tractor and implements. I found the correct size belt there. Do you have a farming store or garden tractor service store in our town? If so try that.
