How to Store Small Engine??
52BMAN
10-02-2006 09:45:45
I have a newly rebuilt 7 HP engine. I want to store it away until Spring. Should I store it dry or put oil in it?? Thanks!! Mark
John W Boutilier
10-29-2006 18:31:12
 Re: How to Store Small Engine?? in reply to 52BMAN, 10-02-2006 09:45:45
I have had mine for 18 years and always run it dry of gas in the fall and left it in an unheated shed. Never changed the oil and it has always started first pull every spring. I found it on LONG iSLAND. a 3.5 HP Tecumseh. Amnd they say a Tecumseh ain't any good. Ha!!
Kent of SW MO
10-03-2006 06:22:29
Very good info here and I agee with it all, but most of the time they are store where ever is handy with no prep.
Kent
Al m
10-03-2006 04:12:01
I would concider a bit of stabile in any gas that remains in the tank.Running it until it runs out of gas can also help reduce varnish forming in the carb.
Al
El Toro
10-03-2006 02:55:53
You have received good suggestions on storing your engine. I would keep the engine in a dry building. Don't keep it in your basement, they're too damp. Hal
ebbsspeed
10-02-2006 11:12:02
I'd fill it with oil and also drizzle a little into the spark plug hole, then turn it over a few times. Throw a cloth over it, store it in a dry place and it'll be good to go next spring. Some folks put 'em in a plastic bag, but unless you also put a couple bags of dessicant in there with it, you may end up with moisture trapped in the bag and damaging something.
Jeff
10-02-2006 16:45:22
 Re: How to Store Small Engine?? in reply to ebbsspeed, 10-02-2006 11:12:02
To go one step further (I agree with the oil plan) I would even grab the flywheel and give it a turn or two every once in a while throughout the winter. Keeps everything lubricated.
