1450 Cadet lives again
Darald Marin
10-10-2006 19:31:31
The 1450 I brought home 10 days ago, has been stumbled around in front of the shop until today. We put in the shop, new front tires, battery, blew the dirt off, removed the carb and cleaned it, new plug, new oil and a few squirts in the cylinder and turning over by hand. The key is missing so the previous owner had it permanently hot wired, and jump start under the dash to run the starter. It had spark so we fueled it up and it fired on the first hit, started on the second. Try this with the choke cable broken off and running the choke with pliers. I drove it around the yard, no viberations and the hydro seems to work good. Hydraulic also works good. The hydro filter is yellow, does that mean that it has never been changed? Should I change the oil and filter in the hydro? The steering is sloppy at the junction of the steering box and the arm to the spindle. I need key and PTO switches, tail lamp, dash decal, choke cable, hydro knob, steering link and a seat. Where is the most likely place to find these items. Thanks...Darald
TractorLarry
10-11-2006 09:45:55
 Re: 1450 Cadet lives again in reply to Darald Marin, 10-10-2006 19:31:31
If yours is anything like my 1864, the keys are standard and not specific to a tractor.
Sears has them hanging on the wall @ 2 for about $4.
-Larry
Kent of SW MO
10-11-2006 05:44:15
The last hydro filter I bought at the local IH dealer was yellow so you can not be sure if the hydro oil has been changed. Change the oil and filter. Then use a scribe or ice pick to scratch the date of when the work was done in the filter so you will know.
Kent
R Bedell
10-11-2006 01:07:56
Parts are available at your local Cub Cadet or Case-IH Dealer.
There are a few online Website, such as:
www.ccsupplyroom.com
www.cngco.com
www.ihcubcadet.com/Sponsors/Madson
www.rfhoutzandson.com
oldrustycars
10-14-2006 10:30:09
 Re: 1450 Cadet lives again in reply to R Bedell, 10-11-2006 01:07:56
try r.f. houtz and son in elburn, il. he has a huge yard of cubs being parted out. also sells new tractors and parts, and is a truly decent human being. all of his staff knows what they are doing too.
