Blade for JD 300 series
SMA in NE
10-19-2006 19:34:03
I have found a JD blade for sale for a 300 series John Deere. It is hydraulic lift and hydraulic pivot and appears to be in pretty good condition. How much should it be worth? He is asking $550, seems high to me.
Ed ...Va..
10-25-2006 18:22:15
 Re: Blade for JD 300 series in reply to SMA in NE, 10-19-2006 19:34:03
check E-Bay auctions, that will give you an idea what others are paying... these blades do run higher than other styles.. Ed
tcwinkc
10-19-2006 20:48:16
Here in MO they usually go between 300-400 dollars depending alot on condition.I would check serial number to make sure it fits your 318, alot of blades look alot alike but are significantly different sizes at the hitch. Dealer ca make sure serial number fits your unit.
