JD 70 steering binding HELP!
52BMAN
11-02-2006 09:21:54
I have the steering box out of my JD 70 L&G. I have installed new bearings, but the shaft still binds when turned. What esle could be the problem and what is the fix. Thanks!! Mark
chevy65
11-03-2006 03:30:38
 Re: JD 70 steering binding HELP! in reply to 52BMAN, 11-02-2006 09:21:54
Does the steering bind in only 1 spot or all over ????? ?
There is a tapered stud that goes into the worm gear with a jam nut that locks it
If thats to tight it will cause binding
Or adjusting plug in bottom is to tight
Good Luck
