18 HP Onan Replacement
Jim
08-11-1999 19:12:22
I have an old Sears 16hp with a blowen engine and have be told the 18 HP Onan will fit. I found the engine in Northern Hydrolic for $1250.00, it sounds a little high priced. Does anyone know where I could find a better price. Thanks for the help. Jim
jeff
11-28-2000 08:58:26
 Re: 18 HP Onan Replacement in reply to Jim , 08-11-1999 19:12:22
Hi, don't know were you can get one but I have one still runnung and need information on it. I put it on a super 12 sears that blew up. I had to weld on the frame to mount it up and use te same belts the 12 did. I am having some troubles with starting (starter) and govener. If you have information could you send it on?? Thank you and good luck.
Michael Sullivan
08-13-1999 14:11:32
I have had problems with the Onan engines, I would recommend the 18hp Kohler Magnum twin cyl. We had a Gravely with the same problem, and we decided to use a Kohler instead of the Onan. I have been very pleased with it, and it has not yet let me down, even when it skidded into a creek and the engine became 3/4ths of the way immersed! Good luck!
