Blades will not disengage
stouto
12-02-2006 18:16:02
I have a Craftsman Riding Mower Model # 917.256522 and the blades will not disengage. The lever will not travel completely to the disengage point and feels to bind. I cannot see where it is binding. Any ideas on how to fix this problem. Thanks.
135 Fan
12-03-2006 09:10:01
 Re: Blades will not disengage in reply to stouto, 12-02-2006 18:16:02
If it uses a cable it might have broke. Always engage at idle at ease it in and out. Dave
Dannie
12-03-2006 07:01:12
Check rod or cable for anything that is holding them from moving full cycle.Also make sure all springs are hooked up on deck.On some Craftsman mowers the control arm becomes worn and will not return the idle pully. Check it also.Good Luck.
