10hp sears suburban
dan m
12-10-2006 09:17:03
anyone know where to get a manual or parts book for one of these?
jake4
12-13-2006 07:50:09
 Re: 10hp sears suburban in reply to dan m, 12-10-2006 09:17:03
Try ths sie operated by Mark Rideout, he has hundreds of outdated manuals. I'll try to put a link, here www.Sears.pammar.net
jake4
12-13-2006 08:21:31
 Re: 10hp sears suburban in reply to jake4, 12-13-2006 07:50:09
Link diden't work type in "www.pammar.net " it'll get you there.
jake4
12-13-2006 07:59:31
Link doesn't work just type in pammar.net and it'll get you there.
Wrench Spinner
12-10-2006 11:49:51
I have owned 7 of these tractors at once I got in a package deal. I have sold all but one hydro machine, You can look at diagrams and get part numbers from (here) but most parts are unavailable through Sears.
traper
12-10-2006 10:47:55
If this an older machine [blue/white should have been built by roper.
Jerry Coulter
12-10-2006 16:33:51
 Re: 10hp sears suburban in reply to traper, 12-10-2006 10:47:55
If it is blue and white 6 speed, that is 3 speed with a high/low, it was built after 1965 by Roper. If it is a blue and white with variable speed belt drive and clutched by a F-N-R lever, it was built before 1966 by David Bradley. I own some of each.
dan m
12-10-2006 17:57:33
 Re: 10hp sears suburban in reply to Jerry Coulter, 12-10-2006 16:33:51
thank you, it is the belt drive variable speed. i didn't know it was that old . what i'm looking for is the size for the belts. any chance you would have this information?
Jerry Coulter
12-11-2006 11:45:36
 Re: 10hp sears suburban in reply to dan m, 12-10-2006 17:57:33
I can't read the numbers on my belts any more, but let me walk you through this exercise.
I log into sears.com, search Lawn & Garden for parts. Next search your model number (mine is 917.60646) for models. That will take you into a choice of illustrations (blurry) or list of parts. Go to steering. #37 is the long belt and #43 the short one. Click the + on each line and go to shopping cart. You will find your belts listed with translations to other Sears numbers. And Sears is the most expensive place to buy them. The #37 is a 70" belt and you can see that length built into those numbers. The belts are 5/8" wide. I use a B67 which is 70".
Now I'm guessing! The short belt must be 29", but I can't find a listing on a B that short. But in another list, I find 4L290 which I believe is a fit.
My 8 HP uses the same belts, so I assume these would be your size also.
dan m
12-11-2006 20:15:10
 Re: 10hp sears suburban in reply to Jerry Coulter, 12-11-2006 11:45:36
thank you again. i will measure the belts that are on it. they are a replacement, the long one rides to deep in the pulley for reverse to work. they are also those green belts that never seem to last. i really appreciate the help. i looked at the sears site it was helpful. i see what you mean on the size being in the #. i wish all manufactures would use a # system that works the same. i'm familiar with gates & some others make sense. but i didn't get these untill you pointed it out. thanks again.
