Max rpm setting for sears tractor
alan olsen
12-17-2006 18:47:52
does anyone know what the max rpm setting should be for a 1966 10 hp sears suburan tractor model #917.25110..... ..... Thanks
Kent of SW MO
12-19-2006 06:39:34
 Re: Max rpm setting for sears tractor in reply to alan olsen, 12-17-2006 18:47:52
Most small engines of today use a govenerned high idle of 3600 RPM's. Some of the older B&S, 50's era number series, use 3200 RPM's.
Kent
Kent of SW MO
12-19-2006 06:38:27
Kent
KennyW in CT
12-18-2006 06:20:18
3600 rpm with no load. Adjust the carb under a load as sometimes the engine will hunt at high rpms without a load on it like a deck or snow thrower.
alan olsen
12-18-2006 14:36:18
 Re: Max rpm setting for sears tractor in reply to KennyW in CT, 12-18-2006 06:20:18
Thanks for the info..... .... Alan
Oldmax
12-18-2006 06:18:36
That would be 3600 RPM as with most small engines .
