1450 scrape blade
NCCub
12-18-2006 09:49:17
I have a front scrape blade off of a 1450. Any idea what else this will fit? A guy here at work has a 149.
Thanks,
Kerry
R Bedell
12-18-2006 11:03:05
 Re: 1450 scrape blade in reply to NCCub, 12-18-2006 09:49:17
"IF" you are referring to a Cub Cadet 1450, then the answer to your question is, it will fit any Wide Frame Cub.
NCCub
12-18-2006 13:11:59
 Re: 1450 scrape blade in reply to R Bedell, 12-18-2006 11:03:05
Cub Cadet is correct, do you know what Cub's are wide frames?
R Bedell
12-18-2006 13:40:25
 Re: 1450 scrape blade in reply to NCCub, 12-18-2006 13:11:59
The attachments from a 149 will fit on a 1450 and vice versa.
