Allis Chalmers 410 Points
Andy_MifPA
12-25-2006 10:00:10
I recently bought an Allis Chalmers 410. The points do not work. How can I remedy this situation.
Andy_MifPA
12-25-2006 18:32:15
 Re: Allis Chalmers 410 Points in reply to Andy_MifPA, 12-25-2006 10:00:10
Thanks for the help and the manual links!
El Toro
12-25-2006 16:55:47
Take some 320 grit wet or dry and clean the points. Make sure they are gapped correctly. Take a cotton swab dipped in alcohol and clean them several times. Then see if you have fire at the plug. Hal
Bob
12-25-2006 10:47:34
Your post is a bit vague! (Points don't move, points are stuck, points are shorted, points don't make contact???)
IIRC, your tractor has a 10HP Kohler K241 engine.
You can download and view, (or print) the engine service manual (in .pdf format) at the link below:
