montgomery ward two wheel tractor
amertrac
12-27-2006 09:22:57
i ahve aquired a monkey ward two wheeled tractor with rototiller and snow blade. the only info that is visible on the tractor is on the engine and that is this number 2220469 does anyone have info on this or know i can get info thanks bob w.-s i believe it has wico elect.
Leroy
01-03-2007 17:37:28
 Re: montgomery ward two wheel tractor in reply to amertrac, 12-27-2006 09:22:57
Some had Clinton Engines and others had the Wisconson engine, and different versions had 4:00 X 12 knobby tires while others had 5 X 12 or 6 X 12 bar tread tires. Have I believe 4 of them here and a lot of catalog information out of the Wards Farm Catalogs. From 2 HP to 5+HP.
Larry Pate
04-13-2007 16:46:03
 Re: montgomery ward two wheel tractor in reply to Leroy, 01-03-2007 17:37:28
I bought a Montgomery Ward garden tractor Model
MID 5055A. I understand that it was made by Midland. Do you know how I might contact Midland? It is a Ward's Power Trac
Leroy
01-03-2007 17:40:49
Just checked and some had up to a 7 1/4HP engine in Briggs as one of the later models in 1966
jdemaris
12-27-2006 19:20:25
It's probably a Wards Plow-Trac made around 1948. Has a Wisconsin AB three-horse engine. Later models got a Briggs & Stratton instead. Should have 5.50 X 12" wheels, three-speed (three groove) pulley and weighs 300 lbs.
Tinker In TN
12-27-2006 18:12:38
If the engine has a WICO magneto, it is probably a Wisconsin engine. The Montgomery Ward tractors were made by Midland, and Simplicity.
El Toro
12-27-2006 13:30:40
You should post a picture of that tractor. My neighbor had one of those. I think it was called the Plow Chief. He died not sure what happened to the tractor. Hal
amertrac
12-27-2006 16:54:33
 Re: montgomery ward two wheel tractor in reply to El Toro, 12-27-2006 13:30:40
i would but i shoved it in ashed . plus my dig camera broke and santa did not give me a new one.
after the snow stops i will pull it out and use my old film type camera
