William Pearson - need info on WH hydro filter
perry in mi
12-29-2006 04:42:52
lookin for a cross reference # for my wheel horse 877 hydro filter. a fella on another board told me fram PF16 , but he wasent 100% positive on that number. i cant read any #"s on mine. who knows how long its been on there.
artlee
12-31-2006 20:57:40
 Re: William Pearson - need info on WH hydro filt in reply to perry in mi, 12-29-2006 04:42:52
that filter crosses to STENS #120-265 and is about 6 bucks
i use them in all of my tractors including the pullers and never had a problem. the problem with automotive ones is they are the wrong microns and can starve the pump for oil
art
William Pearson
12-29-2006 18:17:56
Perry,
The original part number was 5990 then it was superceded to 102819 (red housing) and now 79-5270 (black housing). This filter and fluid should be changed once a year or every 100 hours.
I do not recomend the Fram filter PF-16 even though it will fit it does not have the correct flow for the Wheel Horse hydrostatic.
Bill in Richmond, Va.
El Toro
12-29-2006 10:10:29
third party image
I called our local auto parts store and that 5990 filter crossed to Fram's PH16. I 've been using them for 35 years on that Wards tractor. Never had that hydro apart. I use Dextron ATF in it too. It has woked hard over the years pulling that moldboard plow. Hal
JT
12-29-2006 08:12:48
the Wheel Horse part number is now a 79-5270, sells for 11.42. I guess to each his own, but for $11.42, I would not buy an aftermarket filter to save $5-6.00 on something as critical as a hydro filter.
El Toro
12-29-2006 08:01:14
The Wheelhorse part number is 5990 on your filter.
Any local auto parts store should be able to cross-reference the number. My Wards tractor uses the Fram PH 16 filter. Hal
