Benefits of solid state ignition?
oldrustycars
02-27-2007 14:43:33
I have some Kohler K-301's. Still have points, which I usually change once a season, and use the proper method of the timing light to set them. Im assuming someone makes a solid state ignition for these. Is there a benefit, other than not changing points? I dont seem to have starting problems, even though they sometimes get stored outside in the rain, or in below zero weather. These are on Cub Cadets, its fairly easy to change points. Thanks.
IH2444
03-02-2007 10:43:41
 Re: Benefits of solid state ignition? in reply to oldrustycars, 02-27-2007 14:43:33
If you have to change points often , change the condenser.
Bob 1450
02-28-2007 16:15:06
My 2 "69" 14hp K-321"s have the orig. solid state ignitions and haven"t touched them in over 15 years of owning them, except to change spark plugs.
IMO they are very good systems.
Dannie
02-28-2007 02:05:50
I have not changed points in my Cub for 5 years and it sats out also.The solid state ignition is up to you if you want to try it.
R Bedell
02-27-2007 14:51:50
Yup....You are basically right. Less frequent points changes. Click on this link. Scroll down to the "point saver" section.
