AC tiller grease problem
skubbs
03-16-2007 12:35:45
Hi,
I have a 36" AC (Simplicity) tiller for my AC 916. I just changed the tines (the one who said they were pricey was right...$160.00) and greased shaft where it enters the gear housing. There is a grease fitting on each side of the housing. One takes grease well, and the excess comes out around the shaft. The other fitting doesn"t take grease well. The grease squirts out in tiny streaks between the gear housing and the bracket into which the grease fitting is threaded. No grease comes out around the shaft. What could be the problem? Any solutions before I start taking it apart?
Thanks,
Steve
oldrustycars
03-16-2007 13:20:51
 Re: AC tiller grease problem in reply to skubbs, 03-16-2007 12:35:45
Take the fitting out and try digging the old grease out with a seal pick. Another thing you can try CAREFULLY is to heat up the area, then pump in fresh grease. The heat will melt out the old hard grease, but be careful, as hot grease spraying out will stick to skin, and wont wipe off easily.
skubbs
03-16-2007 15:07:29
 Re: AC tiller grease problem in reply to oldrustycars, 03-16-2007 13:20:51
Thank you,
I took off the grease fitting and probed around, but couldn't find any hard grease. The grease was normal.
