Kohler engine problem on Wheelhorse Tractor
Allan Berwick
04-02-2007 02:47:09
We have a Wheelhorse tractor with a Kohler engine.
We started it the other day and it ran for about 50 metres then stopped. There is fuel in the tank and there doesn't seem to be a problem with the battery or spark plug.
The fuel runs to the carburettor but when we removed the spark plug the ignition chamber is dry.
Could this be a fuel pump problem. Anyone any ideas?
Ron Dorn
04-04-2007 10:17:46
 Re: Kohler engine problem on Wheelhorse Tractor in reply to Allan Berwick, 04-02-2007 02:47:09
I just had a similar failure on my Kohler Courage engine (Craftsman GS6500 used for a LOT of snowblowing). The problem was just a loose wire leading to a solenoid in the carburator. It had good gas, dry plugs, good flow through the fuel filter... like yours. The repairman found it first by listening for a click in the carb when the ignition was turned on, then tracing the circuit back, first through a connection under the air cleaner (ok) and then to a quick connect between the dash switches (pto and ignition).
deanop
04-02-2007 04:54:56
Pretty much what el toro said..Depending on what engine you've got you've either got a shot fuel pump (if applies) or the float/needle sticking or plugged orifices sp. in the carb..what size is the motor...deanop
El Toro
04-02-2007 04:00:07
Do you have fire to the sparkplug? Pull the plug wire off the sparkplug and hold it away from the plug while someone cranks over engine. Should have a nice hot spark when firing. If you have good fire here install a new plug. If the engine
doesn't start pour about a teaspoon of gas down the sparkplug hole, reinstall the plug then see if the engine starts for a few seconds. If it does you are not getting fuel to the engine. You could have a plugged inline filter or there's dirt in the carburetor or gas line. If you have fuel to the carburetor I don't think there's a fuel pump on that engine. The gas probably gravity flows to the carburetor. Hal
