16-18hp Briggs boxers...
JoeK(WI)
04-18-2007 10:48:48
On the newer ones a screw in plug replaces the adjustable jet....has anyone/or does anyone know,if the jet/needle from the older carbs can replace the"fixed" jet?Or is the carb intenally different?I have a "fixed jet" one here that I absolutely cannot get"dialed in" :(
Kent of SWMO
04-19-2007 06:07:13
 Re: 16-18hp Briggs boxers... in reply to JoeK(WI), 04-18-2007 10:48:48
The plug is so you can replace the main jet. The plug also allows easy access to the jet when the engine gets a few hour on it and need a little richer mixture. You can increase the size of the jet with a set of NUMBER sized drill bits. I normally find the bit that will slip into the jet and then drill the jet out one drill size at a time until the engine is nit running lean. If you go to far you can replace the jet and start over.
Kent
Dannie
04-19-2007 00:51:24
Will not fit.
JoeK(WI)
04-19-2007 04:45:56
 Re: 16-18hp Briggs boxers... in reply to Dannie, 04-19-2007 00:51:24
Thanx,guess I'll be Ebayin fer a carb.Got luck on a Tec carb last mo,found one for 4.99.
