15 H.P. Briggs Question
genos
04-23-2007 21:11:36
I have a 15 hp briggs vertical on a dixon, model
28Q777. it runs fine until hit bump, then the
crancase breather tube pumps oil into air filter & carb. no it does not have too much oil in it. thanks for the help
lawrenceq
06-07-2007 23:19:11
 Re: 15 H.P. Briggs Question in reply to genos, 04-23-2007 21:11:36
I think it's the rings.
Andy Motteberg
04-27-2007 08:36:10
Hone the cylinder and put in new rings. That might fix it.
joe csuti
04-25-2007 03:43:01
I can offer two other thoughts as to cause of your problem,if you are using mower for commercial work(yard mowing service) or have large acreage you are mowing & eng has high running hrs,rings may be worn or you have a broken ring,either one will allow blow-by and put compression into crankcase,with pressure in crankcase raising oil level & hitting bump may be just enough to put it over the line & pump oil out breather.
genos
04-24-2007 18:16:40
Already Cleaned Valve, Guess I'll Replace It, looked like it was working, this is the 4th year for this mower and this just started, i changed oil again & Measured it out in a container for the correct ounces, even put on another new filter. when you start it it's ok but as soon as you start mowing & hit a bump it puts enough oil into air filter to soak filter and choke engine & it really smokes going into carb. those briggs air filters are $15 each & their junk after soaking in oil. Gene
joe csuti
04-24-2007 03:03:40
If you are mowing on more that a 12-15% grade with carb & breather tube on low side of angle(closest to ground)this is normal at above angle or greater,oil inside eng is running into breather valve at this angle,if happening on level ground,remove breather valve & check that disk in same is not broken or sticking & need a cleaning.
