1641 Cub Cadet
Pit Crew
04-25-2007 18:56:51
got help here before in the past,(thanks) and need some help again. My 1641 will be 12 years old this June and has 403 hours on it. Last night I was mowing and noticed it was smoking.Later discovered it was not out the exaust but leaking oil and burning on the engine. It looks as if a seal maybe leaking in front of the motor where the crank comes out. Is there a seal there and how hard to replace it. Thanks in advance, Pit Crew
stronics
04-26-2007 16:57:23
 Re: 1641 Cub Cadet in reply to Pit Crew, 04-25-2007 18:56:51
Yes there is a seal on both ends of the crankshaft at the block. Other than getting to it it isn't a big job. Hardest part is getting the old seal out. Then just tap in a new one with the proper seal driver.
David
Pit Crew
04-26-2007 18:27:43
 Re: 1641 Cub Cadet in reply to stronics, 04-26-2007 16:57:23
Thanks David. Where is this breather and could it need cleaned or replaced. The front seal I dont think would be hard to get to. Any tricks to getting the old one out? Thanks, Pit Crew
stronics
04-26-2007 17:01:42
Just another thought. It could be the crankcase breather not working properly. They allow the crankcase to operate in a slight vaccum. If allowed to build pressure it will blow oil out of the seals.
David
