13 OHV Tecumseh
R. Ross
04-25-2007 20:35:00
Would the motor turn over, even if one of the safety switches are activated? I"ve got the motor to crank, just wont start. I have checked for spark and I have a faint one. I have replaced the plug and fuel line and battery and also cleaned out carb. So if anyone has anymore suggestions please share! Thanks
Andy Motteberg
04-27-2007 08:33:37
 Re: 13 OHV Tecumseh in reply to R. Ross, 04-25-2007 20:35:00
Does it have good compression?
IH2444
04-26-2007 07:46:22
Does the plug smell of gas or is wet with gas after cranking ? ie is the combustion chamber getting gas to ignite ?
Kent of SWMO
04-26-2007 06:45:53
Some mower only kill the ignition withthe safety switchs. NEED more info on the type of machine you are working on.
Kent
Roy in UK
04-25-2007 22:29:15
Blocked air filter?
