11-HP Briggs Engine
jb9959
04-30-2007 06:34:08
When I first start up the 11-hp Briggs engine, it runs cold and a bit sluggish. Before it gets warmed up, I get a lot of smoke for about a minute.
After the smoke clears away the engine will run for hours without any more smoke. I wonder what causes this?
JB9959
Andy Motteberg
04-30-2007 13:23:00
 Re: 11-HP Briggs Engine in reply to jb9959, 04-30-2007 06:34:08
Sounds like you have worn piston rings or a carb problem. Clean the air filter. Inspect the rings and hone the cylinder before installing new rings.
JoeK(WI)
04-30-2007 07:29:05
Usally just an indication that a verticle shaft engine has some wear.While setting a bit of oil can seep past worn rings etc into cylinder,and when first started needs to be burned off.Can foul plug slightly,causing operator to apply more choke than normal,creating a slightly flooded condition.Takes a "minute" for cylinder to clear/warm/burn the excess gas/oil.Usually not critical,just check oil regularily(as one should anyway :)
jb9959
04-30-2007 07:45:30
 Re: 11-HP Briggs Engine in reply to JoeK(WI), 04-30-2007 07:29:05
Thanks.
It does use oil. This engine is on a Cub Cadet 111 which is quite an old tractor.
