Vanguard v twins
Al m
05-05-2007 04:37:47
I have installed a 16hp vanguard in a older simplicity.There is no room for the oil filter.Can the filter assy be blocked off with a plate and ran like that?I think I seen this done on a jd 140 conversion but am not sure.
Thanks
Al(i have a remote filter kit coming but could use te tractor now)
Ken Combs
05-05-2007 08:10:37
 Re: Vanguard v twins in reply to Al m, 05-05-2007 04:37:47
I think there is a kit available from Briggs to run a remote filter. Adapter plate, hoses and remote mount.
As the earlier poster said, just blocking it off will block all oil flow and ruin the bearings within seconds.
Bob
05-05-2007 07:55:09
The filter is "full-flow", and you can't block it off unless you have the appropriate plate with and oil channel to let the oil flow through the block-off plate, from on port in the engine to the other.
Al m
05-05-2007 14:36:07
 Re: Vanguard v twins in reply to Bob, 05-05-2007 07:55:09
Thanks Bob,I will wait for the remote kit
Al
