Kohler K321S 14hp oil capacity
AlexLV
05-08-2007 21:12:12
What's the oil capacity of a Kohler K321S 14hp 1 cyl. engine?
Kent of SWMO
05-09-2007 06:31:37
 Re: Kohler K321S 14hp oil capacity in reply to AlexLV, 05-08-2007 21:12:12
K-series Kohler use some differant oil pans. Some are 1 1/2 Qts. some are 2 Qts. The oil capacity can be found by using the spec number to I.D. the pan.
Kent
steve from mo - dangit!
05-09-2007 06:29:12
There are at least two different oil pans for these engines. The spec number on your engine should let you look it up unless the pan has been changed. The deep pan used the long dipper on the road, and the flat pan (obviously) would use the short dipper.
Jeff
05-09-2007 04:55:13
The book for my Power King says 4 pints or 2 qts.
El Toro
05-09-2007 04:35:00
Whenever you are in doubt about the oil capaciy is to only fill to the full mark on the dip stick.
I had a JD140 with the 14 hp Kohler and I think it held 2 quarts too. Hal
PS: smallenginewarehouse still have the K321 engine for sale and they list the oil capacity at 2 qts.
Bob
05-09-2007 07:54:02
 Re: Kohler K321S 14hp oil capacity in reply to El Toro, 05-09-2007 04:35:00
Deere 140's use a special shallow oil pan, and hold only 1-1/2 pints.
IIRC, the 140's engine # ends in "AS", with the "A" meaning "special oil pan", and the "S" meaning "electric start".
R Bedell
05-09-2007 02:36:17
All the Cub Cadets with 14HP K321 Kohlers used 3 Pints.
Leland
05-08-2007 22:46:58
2 qts I belive thats what mine held
