110JD
70D
05-09-2007 10:16:02
The two drive belts I want to replace do I need to use John Deere brand or can I use gates napa etc belts and if so does and one have the size for these two My mower is mid 1970
BUTCH GA.
05-09-2007 10:28:45
 Re: 110JD in reply to 70D, 05-09-2007 10:16:02
70D I used John Deere belts primary belt # M82258 rear belt # M44121 thats J.D. part numbers and make sure you have the belt guard that goes around the front pulley in place or you will have trouble shifting it in gear. If you need a very good source for parts contact Lundell Tractor in Kiron Iowa. phone # 712-675-4341 they are a retirement center for old John Deeres very nice folk to deal with. they can supply any part you want.
chevy65
05-10-2007 18:55:22
 Re: 110JD in reply to BUTCH GA., 05-09-2007 10:28:45
You got to use Deeres belts or your variable speed wont work correctly
The belts are persion to work with the variator
