BS Model 42A707, Type 2238E1
jb_can_ga
05-10-2007 19:08:16
I purchased a 1997 model 18.5 Briggs & Stratton Model 42A707, Type 2238E1 Code 9709295B. The motor arrived with a crushed starter.
Can anyone tell me the replacement part number and if this is a major job to replace.
Thanks!
Jim
Canton GA
jb_can_ga@yahoo.com
joe csuti
05-11-2007 03:07:04
 Re: BS Model 42A707, Type 2238E1 in reply to jb_can_ga, 05-10-2007 19:08:16
Try going to www.mfgsupply.com,search item# sbsooo9($80)you could also try www.jackssmallengines.com & www.outdoordistributors.com and check prices or check around on ebay in outdoor power equip-lawmmowers-multi use eng-briggs for a used one.your starter part#498148(long frame)as far as changing,2 bolts holding starter yoke to eng block,you might have to pull shroud on eng to get to bolts.
joe csuti
05-11-2007 17:39:14
 Re: BS Model 42A707, Type 2238E1 in reply to joe csuti, 05-11-2007 03:07:04
Starter part# at mfg website should be sbs0009,I typed o's,should be zero's-sorry
jb_can_ga
05-12-2007 18:13:56
 Re: BS Model 42A707, Type 2238E1 in reply to joe csuti, 05-11-2007 17:39:14
Joe ...
Again, thank you for the help. I ordered the SBS0009 - B&S Long Case Starter from www.mfgsupply.com.
Regards, Jim
jb_can_ga@yahoo.com
jb_can_ga
05-11-2007 15:44:40
Joe...
Thank you for the part number info and suggestions!
Regards,
Jim
Dannie
05-11-2007 01:14:03
Starter not hard to replace,cost about $160. How did the started get crushed without doing more damage?
jb_can_ga
05-11-2007 15:42:28
 Re: BS Model 42A707, Type 2238E1 in reply to Dannie, 05-11-2007 01:14:03
The motor was shipped to me lying on its side, starter down. Was packed in foam peanuts but must not have had much foam under that part.
Hopefully only the starter is broken. I haven"t started any disassembly yet so fingers crossed.
Thanks for the info!
Jim
