682 cub pump leak
curtiss
05-14-2007 17:25:52
i have a 682 cub leaking oil from the pump on top where it looks like two big nuts on the pump housing. its on the full mark on the dip tube. it seems like its building up pressure. after sitting over night theres a puddle under the trans anyone have any ideas.
Kent of SWMO
05-15-2007 06:25:07
 Re: 682 cub pump leak in reply to curtiss, 05-14-2007 17:25:52
I had a 140 JD do the same thing. The valves on the JD were the unloader valve that when open allow you to push the tractor. It's problem was that over the years the piece of sheetmetal that pushed on the valve when you screwed the unloader screw down was pushing all of the time even though the screw was not against the sheet metal. The valves would leak until the trans.built enough pressure to push the metel up. It took a whille to find this. I bent the metel up and the valve stop leaking. This may be you problem or your unloader valves may need replacing.
Kent
