318 running rough
Aaron G
05-14-2007 18:45:17
I was mowing today and it was running great then it about ran out of gas so I switched to reserve with it still running and drove for a couple minutes to the barn to get gas. I filled it up and switched it back to gas on with the tractor not running. I started it back up and it was idling real rough. I then turned to blades back on and it ran better and I finished mowing about 20 minutes worth. When I was done and turned to blades off it started idling rough again. Simple problem or not. Any help will be appreciated. Thanks
chevy65
05-14-2007 18:57:18
 Re: 318 running rough in reply to Aaron G, 05-14-2007 18:45:17
Probably sucked some dirt from bottom of tank
A good carb cleaning would take care of it
Some 318 tractors had a carburetor u could adjust the air jet
If urs has 1 open it up some this may help it pass the dirt
Pulling the carb is no fun on a Onan engine
Usually u can pull the top off it with carb still on engine an clean bowl an jets but for a total clean it must be removed
