An Easy Way To Start An Engine
El Toro
06-05-2007 09:06:31
Here's an easy way to start a rope start engine.
Got tired of pulling that rope. This is a
31-inch Toro composter mower and it has the B&S 23B engine on it. I had to have the cylinder bored .020" oversize and the crankshaft ground .020" undersize in 1993. Our local machine shop did the work. I reassembled the engine with new ball main bearings, piston and rod. The shop installed a new exhaust valve too.
Still has a lot of compression. Hal
third party image
onefarmer
06-11-2007 13:57:51
 Re: An Easy Way To Start An Engine in reply to El Toro, 06-05-2007 09:06:31
Posting both pics
third party image
third party image
El Toro
06-11-2007 14:08:27
 Re: An Easy Way To Start An Engine in reply to onefarmer, 06-11-2007 13:57:51
I must of left out a letter or number. Hal
onefarmer
06-11-2007 14:14:07
 Re: An Easy Way To Start An Engine in reply to El Toro, 06-11-2007 14:08:27
Sent you an email
joe csuti
06-05-2007 18:25:30
You take all the fun out of it,you haven't lived till you try to start one of there monsters in winter below 30 deg without putting a 150w flood lamp against block for 30 min before starting,been doing this on an old tiger tractor for past 33 yrs that I used in winter for 23 yrs with blade & last 10 with a blower,taking same to bone yard this week & finally putting to rest(mag coil bad & burns oil)feel like I'm killing an old friend.
El Toro
06-05-2007 18:44:16
 Re: An Easy Way To Start An Engine in reply to joe csuti, 06-05-2007 18:25:30
I will soon be 75 and I've done my share of the pulling. I let that 14 Briggs do thr work and it never complains. I don't think the governor even opens up. That Toro Grassking has Whirlwind on the mower can chew up some grass. I even mow off the garden with it. Hal
perry in mi
06-05-2007 14:36:01
looks like a good idea. thanks for posting..... .....
perry in mi
06-05-2007 14:29:33
third party image
get it together there hal. youll get"er eventualy. dont you just hate the red X .
El Toro
06-05-2007 14:59:18
 Re: An Easy Way To Start An Engine in reply to perry in mi, 06-05-2007 14:29:33
I get them once in a while even though it was posted right. How did you get that web site to appear? That belt I use is 5/8' X 96." Hal
El Toro
06-05-2007 09:12:29
Let me try those pictures again. Hal
third party image
third party image
perry in mi
06-05-2007 14:44:24
 Re: An Easy Way To Start An Engine in reply to El Toro, 06-05-2007 09:12:29
hey hal. forgot to tell ya, i have wards tiller,tractor,and mower parts on ebay right know. just in case you need something. i have a feeling im going to be trying out that belt starter set-up in the future. did the belt slip much?...
El Toro
06-05-2007 14:52:50
 Re: An Easy Way To Start An Engine in reply to perry in mi, 06-05-2007 14:44:24
It may slip a little on the mower pulley. I grab the mower handles to tighten the belt while I'm cranking it with the pto from the tractor. I have a spare generator I could install on it as some of these mowers had electric start. This is
easier. Hal
El Toro
06-05-2007 09:15:34
third party image
Here's the other picture. Hal
