Engine not firing
m.d. sawvell
09-09-1999 09:10:46
what might be the cause of the engine not firing. it's a 11 hp brigs with electronic ign.
john d
09-09-1999 16:22:56
 Re: engine not firing in reply to m.d. sawvell, 09-09-1999 09:10:46
Check for a partially sheared flywheel key. Also for a defective shut-off switch that isn't opening. Following those items, you may have ignition module or coil problems.
sam
09-09-1999 20:06:14
 Re: Re: engine not firing in reply to john d, 09-09-1999 16:22:56
make sure the coil is the right distance from the flywheel, this can be checked with a business card, which should fit right between the coil and the flywheel. If it still doesn't fire, try isolating the coil by disconnecting the kill wire directly at the coil, then crank the engine to see if it fires. If does not fire, then you need a new coil
