11hp Briggs camshaft ques.
jav
06-12-2007 12:08:13
I have 2 Briggs model 252707 engines. One has the cast iron bore, the other is aluminum. The iron bore cam measures at 1.208 int./exh. The other cam is 1.257 int./1.208 exh. Can I use the alum. engine cam in the cast iron engine without any problem?
oldrustycars
06-12-2007 13:54:51
 Re: 11hp Briggs camshaft ques. in reply to jav, 06-12-2007 12:08:13
you can look up the part numbers on the BS web site, with the model and type numbers, then you'll know if they are the same.
