Bolens 1050 engine problems
Phil S.
06-19-2007 11:12:30
I have a Bolens 1050 tractor powered by a Wisconsin TRA 10D engine. The engine starts and runs fine at idle. At full throttle, it burps and bellows and blows out black smoke like it is running rich. I have turned the high speed screw in all the way, and the engine still runs and still runs rich. I have had the carb off numerous times, but the engine still runs the same. What am I missing? The engine now has a leak from the governor shaft in the crankcase cover. Is this a tough fix also? Thanks for the help, PHil
Jerry Coulter
06-19-2007 13:38:37
 Re: Bolens 1050 engine problems in reply to Phil S., 06-19-2007 11:12:30
Sounds like a restriction in the air intake such as a closed choke butterfly, dirty air filter, or maybe a problem with weak ignition.
