BS wont start
dswndle
07-14-2007 08:17:42
Battery won't start Craftsman lawn tractor with a 17 hp B&S engine. Will turn a half turn but that's it, almost like there's too much compression. Can jump off with my truck but only when the truck is running. Once started it runs fine. If hot it sometimes starts but if cools a little will not start.
jd b puller
07-16-2007 20:23:26
 Re: BS wont start in reply to dswndle, 07-14-2007 08:17:42
Make sure you don't set them at TDC, go about 1/4 turn PAST TDC, COMPRESSION Stroke.
JT
07-14-2007 11:08:16
Check the clearance on the valves, sounds like your valves are too loose, and the compression release is not working, set them at .004, and you should be good to go.
