Sears 19.9 GT - mowerdeck parts
Andrew Immer
07-14-2007 18:01:21
I have an 80's model garden tractor that I just love, but I bent the center mandrel on a piece of steel yesterday. I don't know the part # TO LOOK FOR AND SEARS says that this is a discontinued part. Any help would sure be appreciated!!!
JT
07-16-2007 10:11:41
 Re: Sears 19.9 GT - mowerdeck parts in reply to Andrew Immer, 07-14-2007 18:01:21
Andrew, If you can get the deck model, or a part number, I might be able to get it for you. I hear this quite a bit that it is NLA from Sears, but it is not, I can still get it.
Jim
Andrew Immer
07-16-2007 16:04:20
 Re: Sears 19.9 GT - mowerdeck parts in reply to JT, 07-16-2007 10:11:41
I have pictures, How do I put them on here?
joe csuti
07-16-2007 03:19:18
goto www.mfgsupply.com & search items# 10-2914,10-8648 & 10-8649,see if any match.
joe csuti
07-15-2007 18:06:41
Try going to www.jackssmallengines.com at home page scroll down & click lawnmower and tractor parts,at next page click deck parts,at next page click ayp & see if any or assemblys match yours.
Andrew Immer
07-15-2007 18:59:23
 Re: Sears 19.9 GT - mowerdeck parts in reply to joe csuti, 07-15-2007 18:06:41
It is similar to part 285878, but not identical.
joe csuti
07-15-2007 06:08:26
Went to sears site only show tractor-Is there a seperate id tag on deck with a model or part# on same?Did find decks on another site,looks to be 3 possible hub assemblys used ,2 are rebuildable(mandrel,shaft & bearings)but need deck drawing for oem part# as decks avail in 36"-50" size,or if you can get part# for mandel from sears(even though nla from them),post here & will see if I can find.
Andrew Immer
07-15-2007 16:59:35
 Re: Sears 19.9 GT - mowerdeck parts in reply to joe csuti, 07-15-2007 06:08:26
It is a 48" deck - no numbers or tags. This hub has the double pulley v's
Dude11
07-14-2007 20:40:45
You might want ck on ebay.I've seen quite a few different ones.You'll need to know model#Dude11
joe csuti
07-14-2007 19:08:43
What's the sears mod# of tractor?
Andrew Immer
07-14-2007 20:51:23
 Re: Sears 19.9 GT - mowerdeck parts in reply to joe csuti, 07-14-2007 19:08:43
917.257080 I'm also looking for a dash/console for the same tractor Thanks!
